Hey I've got a problem here. I've got 10 mpegs around 50 megs each that I made a bin/cue out of using VCDEasy. VCDEasy doesn't read my burner so I use Nero to burn the bin/cue files. In VCDEasy it says that the CD size will be 459MB, but when I try do burn the image using Nero it says in the info section b4 burning, that each track is 459MB EACH, at around 5GB total. I'm thinking man, that can't be right, 50MB files being turned into 450MB files?? Can anyone here help me with this? Should I use a different program to burn or something? Any help on this would be appreciated, thanx.
Results 1 to 9 of 9
You are probably using an old version of Nero that didn't know how to burn CUE/BIN images correctly.
If you must use Nero to burn CUE/BIN images (not advised) then update to the newest v5.5.x release.
As for VCDEasy / CDRDAO, that is highly recommended. Have you tried updating / installing the ASPI layer with ForceASPI? http://www.vcdhelp.com/tools
If not, give it a go. It tends to fix this problem. CDRDAO should be able to burn to just about EVERY modern internal IDE burner.
Regards.Michael Tam
w: Morsels of Evidence -
yes that might b it, u r prolly usin an old version of nero that doesnt werk properly wif cue n bin...get the l8est 1 n u will c that it will work!!! //np btw
Alright man, thanks. I'll try that ForceASPI, and upgrade my Nero as well, while I'm at it.
question about how to burn Nero Image
By jimdagys in forum DVD RippingReplies: 5Last Post: 4th Sep 2010, 11:06 -
How do I burn an Image file (.iso) over 8.5GB???
By Hank Kinsley in forum Newbie / General discussionsReplies: 12Last Post: 26th Sep 2008, 12:19 -
Large[19.5GB] VOB to MP4[H264]
By madmillington in forum DVD RippingReplies: 3Last Post: 6th Feb 2008, 14:40 -
Why won't image burn allow me to write AVI?
By Soccerman77 in forum Video ConversionReplies: 1Last Post: 15th Nov 2007, 17:26 -
Nero won't burn video DVD
By solo_voyager in forum Newbie / General discussionsReplies: 3Last Post: 13th Nov 2007, 21:06
