Results 1 to 10 of 10
  1. i have several movies that i need to remove a clock thats running permantly while the movie is playing, its just below half way up the screen and is very largeand annoying, can anyone let me know how to romove/edit it plz?
    damn you avi encoders, you look so good-but you crash so bad!!
    Mar 2002
    chicago
    you can't
    what are you askin' me for...
    I'm an idiot!
  3. I can! Use virtualdub with the plugin delogo. Works great
    Manchester, England.
    A link would be good.
  5. Member djmattyb's Avatar
    Dec 2001
    Seattle
    I have never used this filter, but I knew where to find it. It's at this webpage here.
    Hope this helps.
    -Matt
    dj matty b
  6. I'm a MEGA Super Moderator Baldrick's Avatar
    3 links within 3 minutes
    I added the delogo link to the faq also.
  7. thanks for all the help guys! u all came through for me
    Wow!
    Speed demons
