Hey guys, I was wondering if any of you could help me out? my dvd drive is ripping the dvds hella slow and was wondering how I can fix it. I did it once along time ago so it would ripp at 10 speed but i forgot how. any of you know? its ripping them at 0.65 speed and I just cant stand the wait any longer. I have a dvd-115 drive. thanks in advanced if you can help me out.
by the way I am using smart ripper to ripp the dvd. thanks again
what OS?? Set Smartripper to use Aspi . You might also (If you have win2k or XP) need to install Forceaspi to add an Aspi layer.
I am Using Win2k and a Pioneer 114 and I get speeds of 6x-7x (using ASPI) -
hi, i have another suggestion if you don't have aspi correctly installed on your computer. I'm using Win98SE with aspi not correctly installed but i usually just copy the folder 'Video_TS' from the dvd onto my hard drive and then use smartripper to select the Video_TS folder and then rip it. I usually get over 10X speeds and i usually just wait about 7 minutes for the copying of the folder onto my hard drive.
hey Executioner how do you do that? I think thats what I did last time and it worked alot faster. thanks for remembering me on that. I just forgot where it was.
You can use Nero DVDspeed to test your dvd-rom speed. If it is slow then you should get a new one.
Ripping speed for dvd-r
By vcd4me in forum DVD RippingReplies: 10Last Post: 22nd Apr 2011, 05:45 -
So what brand pf DVD blanks is everyone using now that Verbatim sucks???
By progrocktv in forum MediaReplies: 82Last Post: 30th Oct 2010, 12:08 -
DVD Fab v/s AnyDVD Ripping Speed
By wulf109 in forum Blu-ray RippingReplies: 0Last Post: 25th Mar 2010, 13:04 -
Question about ripping when internet speed is too slow
By jimdagys in forum Video Streaming DownloadingReplies: 1Last Post: 11th Sep 2009, 02:49 -
jvc sucks!!!
By Marvingj in forum Newbie / General discussionsReplies: 5Last Post: 2nd Aug 2008, 10:36
