    Dec 2001
    monterrey,mexico
    Hello. Can I Make a VCD with 2 selectabke audio tracks? (like in svcds). I heard you cant make it selectable subtitles, but you can put 2 audio tracks. is it true?
  2. Member adam's Avatar
    Sep 2000
    Vcds support one stereo or two mono tracks. Svcds support two stereo or four mono tracks, so no the two formats do not have the same audio capabilities.
    The only way to get multiple languages in a vcd is to encode each channel in mono and then combine them into one stereo track. Some dvd players will let you switch between the two channels, others will let you mute one or the other, and for those players that can do neither you will just have to unplug one of the speakers.
    Do not bother making a dual language VCD unless you really need both languages, because mono doesnt sound nearly as good as stereo.
    If you really need selectable audio tracks then SVCD is the way to go.
    Dec 2001
    monterrey,mexico
    So, how do I combine the 2 diferent monos in 1 stereo?
    tks
  4. Member adam's Avatar
    Sep 2000
    with any wav editing program.
