What is a CUE file? Trying to make a hidden track on CDRWIN and read some where i need to edit the cue file
.http://www.cdrom-guide.com/forums/showthread.php?s=&threadid=14376&highlight=hidden+tracks
The CUE/BIN image format comes as a tandem of two files.
One is the BIN file which contains the actually binary data that is in the CD image.
The other is the CUE file, or the cuesheet, that contains some general information about the structure of the CD/image (e.g., how many tracks, where they are or start, what sort of sectors are used, subindices, etc.)
To MAKE a CUE/BIN image of an existing CD (I assume you want an audio CD), then use CDRWin to extract an audio CD to a CUE/BIN image on your HDD.
Regards.Michael Tam
w: Morsels of Evidence
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 15:25 -
Cue File With Media Player Classic 64
By mugly78643 in forum AudioReplies: 1Last Post: 2nd Jun 2009, 03:42 -
Can you burn a CD-extra using .cue file?
By piano632 in forum AudioReplies: 3Last Post: 15th Feb 2009, 21:45 -
question how to burn bin/cue file to DVD disk
By jimdagys in forum Newbie / General discussionsReplies: 9Last Post: 17th May 2008, 11:58 -
question about how to use cue file to break big audio file into tracks
By jimdagys in forum AudioReplies: 13Last Post: 12th Oct 2007, 08:40
