I was thinking that since everyone has trouble with the Dazzle disappearing from the firewire bus, someone could dump the firmware of the device, find and fix the bug.
or is the device's rom not flashable?
It is a write once device. And the firmware has little to do with the firewire on this device. Yes, I've looked into it a little. Though if you really want to reprogram the sucker, you could then be able to change the video levels and audio levels, etc. If you really want to change the thing, find a philips SAA7115 video chip, and replace the older SAA7114 that is on your bridge now. If you are really into this, the microcontroller that sets up this device uses 8051 standard coding, but I forget who makes it. And I think the rom is in a socket. And the rom has a flashable replacement for cheap.
Hope is the trap the world sets for you every night when you go to sleep and the only reason you have to get up in the morning is the hope that this day, things will get better... But they never do, do they?
LG RH7823W Firmware?
By grungerock in forum DVD & Blu-ray RecordersReplies: 1Last Post: 3rd May 2010, 23:11 -
Custom firmware?
By DGenerateKane in forum DVD & Blu-ray WritersReplies: 6Last Post: 24th Nov 2009, 17:13 -
Upgrading firmware
By tee jay in forum DVD & Blu-ray WritersReplies: 3Last Post: 26th Feb 2008, 13:35 -
Need DVD-RW firmware
By Strutinan in forum DVD & Blu-ray WritersReplies: 5Last Post: 13th Jun 2007, 07:19
