i have a movie(div5.0) that is just a bit long to fit on 700 mb cd. i tried to split it using virtual dub but got this error: "could not locate the compressor for format 'DX50' (unknown)"
any suggestions!
thanks!
tvandang
Can you play it in WMP coz this usually means you don't have the right codec installed. Download and install the divx 5.0 codec or better still, install the Nimo codec pack and solve nearly all your codec problems.Originally Posted by tvandang
i can play the movie in divx player and also in windows media BUT I cannot split in virtual dub.
tvandang -
anyone? help! this is divx movie is "The Rookie" and i really want to put it on a cd...
tvandang -
I have a reason to believe that this might work:
http://www.divx-digest.com/software/xvid.html
Give it a go.
Virtual Dub setting help
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 10Last Post: 27th Oct 2011, 18:55 -
Virtual dub
By santolina in forum Newbie / General discussionsReplies: 4Last Post: 22nd Jul 2009, 14:48 -
Virtual Dub problem
By rocka in forum EditingReplies: 3Last Post: 2nd Jan 2009, 04:46 -
I have a virtual dub question.
By mmmipa in forum AudioReplies: 6Last Post: 12th Mar 2008, 04:34 -
help with virtual dub
By Remyisme in forum Newbie / General discussionsReplies: 7Last Post: 30th Jan 2008, 16:36
