  1. Ok I have been using dvdx for a while now and have not had a problem with it until I tried to encode the 2002 movie spiderman when you convert it to vcd 1.0 the play back is jared and the sound is skiped every 5 secs or so this prob also happens with the DVD Movie Enuff!!! can any one help or do I have to use another converter (note with the same settings other movies come out fine Exp. DVD "Sum of all fears")
    Me specs are Win Xp pro p3/1.1ghz 512 Ram x32dvd ram!!
    Can any one help?
  2. I have had the same problems with that movie and the Cowboy bebop collection. I have not had this problem before with other movies. I've used two comuters one with a P4 1.67 and PII both WINXP with 512 ram.
  3. I have had problems using both Smartripper and DVD Decrypter to get the .vob files for a Divx conversion. How did you get the movie to rip?
  4. have the same problem as suave74!
    also ripped the movie using smartripper 2.41 under xp (celeron 1Ghz, 256 mbram)...
    need help!
  5. i just figured out how it works.
    as mentioned, i ripped movie with SmartRipper to HD first. (whole movie)
    here's the settings for dvdx 2.0
    INPUT:
    - Audiotrack: Engl. AC3 6ch
    - 44.1 kHz no conversion
    - Output Framerate: 24 Hz
    - detect progress. 24 Hz
    - force 24 Hz
    - iDCT: FPU (Best Quality)
    - A/V sync. OFF!
    OUTPUT SETTINGS:
    - anything should work (i tried PAL-VCD & DivX+Lame 192kB/s)
    enjoy
  6. ...well actually you'll have to sync the sound to the video otherwise there will be an increasing delay...
    btw is there anybody still listening...
  7. Ok G roc sorry it took me so long to respond what your method worked great thanks a lott
