Is their a solution to trying to convert an AVI to MPEG2 when the AVI uses different frame rates? Ive 2 movie files, 1 is 12.5fps and the other is 20, both dont seem to work right.
Try TMPGEnc, should encode as you wish, or FlaskMPEG and BBMpeg for MPEG2
<hr>
Well vested in the following: Pinnical DC-10+, TMPGEnc, AVI_IO, VirtualDub, Flask, BBMpeg, SmartRipper, DVD2AVI
<hr> -
I use TMPGE and it doesn't seem to matter what the original avi framerate is, whether i encode to 23 with 3:2 playback or 29 it works. The only problem i found was with audio being out of sync. But that happened even if i was encoding 29.97 avi to 29.97 mpeg2. As i couldn't find any rhyme or reason to when the audio was gonna be out of sync, i load up all my avi in virualdub, save the sound to wav and the video to uncompressed avi. Then I just load up the video and wav in TMPGE and tell it what i want my end result encode to be.
I too would like to know whats really going on. If there is any reason to encode at a factor of the original (ie 15 fps avi to 29.97 mpeg).
If anyone can shed some light i'd appreciate it. -
I figured out the problem I was having was because I didnt have the proper codecs installed. So the file would play fine in Media Player but in TMPGEn would just show a black screen. Its working OK now. The only problem I run into now is it crashes at 4 gigs.
decoding mpeg video into frames say I,P,B frames
By abeer in forum ProgrammingReplies: 44Last Post: 6th Oct 2012, 09:24 -
Virtualdub VCR capture no dropped frames but 5400 inserted frames in 1 hour
By suloku in forum Capturing and VCRReplies: 12Last Post: 17th Aug 2011, 23:33 -
need help unblending previously blended frames rather than dropping frames
By BilboFett in forum Video ConversionReplies: 15Last Post: 12th May 2011, 22:15 -
mencoder: seeking to frames (or cropping start frames)
By manchurian_candidate in forum LinuxReplies: 3Last Post: 13th Dec 2010, 09:53 -
inserted frames without dropped frames in VirtualDub capturing VHS
By whschlebaum in forum Capturing and VCRReplies: 0Last Post: 23rd Aug 2007, 21:59
