I have some dvdrips, i made them into VCDs using Nero, but the sound plays late. Can anyone help me with this problem, I'm new. Thanx in advance
Check the sound again, because you put the sound and video isn't on the right track (I mean exactly the same time).... I think you might put it late after the video start.. so that's why come the problem started late... check it around......
if you used tmpg to encode just go back and use mpeg tools to correct the file use mpeg tools - cut and merge and choose make vcd compliant vcd don't choose auto setting :P
I would advise to use TMPGEnc or any other DEDICATED encoder to encode to (S)VCD. Nero does a lousy job at it since it is designed mainly for burning (hence all the problems that arise when it is used to encode).
3d video with dts sound how to convert to ac3 sound
By fredddiemercury in forum Video ConversionReplies: 4Last Post: 2nd Nov 2011, 15:54 -
Audio Sound File Saved - Canot Hear Sound - Total Recorder
By Teac23 in forum ComputerReplies: 1Last Post: 15th Apr 2011, 15:29 -
Need advice getting rid of buzz sound at end of every word of video sound
By OM2 in forum AudioReplies: 18Last Post: 30th Oct 2010, 12:58 -
What's the best-easily working program to rip sound from vcd ?
By billyww in forum AudioReplies: 1Last Post: 20th Jan 2009, 07:30 -
DVD LAB : Different sound in different movie (MIXED SOUND): NOT WORKING?
By SteamrollerLive in forum Authoring (DVD)Replies: 2Last Post: 24th Jun 2007, 19:01
