Hello all. I use various programs such as iuVCR, VirtualDub, AVI_IO and others. All work great to capture the video/audio. What I need now is a small, free program to capture ONLY the audio. I would prefer to capture it direct to MP3, but if necessary to capture it to WAV and re-process it later I can.
Please, does anyone know of such a tool? Or what about any app that captures audio/video with the ability to turn the video capture part off?
Thanks!
Windows sound recorder, part of every standard windows intsallation, records to uncompressed PCM I believe.
Yeah, you could use that and then compressed it to mp3
This is the last day of the rest of your life -
Sorry ya'll but sound recorder is very buggy & only saves a little amount of time before crashing. Plus encode to MP3 is very slow.
I finally found the perfect application for this, it's called Messer. Anyone else in the future who wants to do what I tried to do, check it out.
Umm with this program I can capture directly from the line-in of my sound card. The recording is done directly to MP3 files at whatever bitrate I want.. And I can record hours of audio without any problems. I can even schedule times of day for things to encode. The best thing is that it's free 100% and so is the lame mp3 codec used to encode the mp3.
Thx again for those who posted ideas. -
Well, i'll give it a try
Best (hopefully free!) software to capture analog video?
By The Big Cheese in forum Capturing and VCRReplies: 3Last Post: 7th Sep 2011, 21:52 -
What would you say is the best free video capture software?
By meneedit in forum Capturing and VCRReplies: 6Last Post: 22nd Feb 2011, 05:48 -
Problem recording audio from screen capture software.
By nick101181 in forum Video Streaming DownloadingReplies: 1Last Post: 12th Sep 2010, 01:40 -
Sony Video Hi-8 Editing Disk Lost. Need Free Capture/Edit Software
By Classic '57 in forum Newbie / General discussionsReplies: 13Last Post: 14th Jun 2010, 23:08 -
Any free, good, reliable software for video streaming capture?
By rob1974 in forum Newbie / General discussionsReplies: 6Last Post: 22nd Sep 2007, 16:26
