www.dvdplayers.co.uk/mercury-220.htm
Check out this CD Player. It is a personal CD Player but it supports MPŁ Discs and VCD's!!!!!!! A Personal CD player which supports VCD's, how? I dont know. Just ordered it, I'll let you guys know![/url]
http://www.first2view.co.uk/Mercury_VCD_MP3_Player_video_on_VCD_.htm
I have the player it will play all your VCDs as long as they are formatted as a standard VCD ie 1150 CBR otherwise it dont matter if they are original or CDR backups ! Also it has to be ran of the mains not battery when playing VCD's !
And its Ł55 from the link above ! 8)KILL A MAN BE A MURDERER, KILL A THOUSAND BE A CONQUEROR, KILL EVERYONE BE A GOD ! -
It "looks" like a clone of the NAPA MP3/VCD portable CD player...
Feature set seems similar/identical too.
If so, you should do a quick review on the comments for the NAPA unit. There are quite a few bad commentaries (and good ones too)...
Regards.Michael Tam
w: Morsels of Evidence -
The quality is as with any movie if the source is good the playback is good !
And yes its basically a clone of the napa units ! the only downside is the lid is a bit flimsy !KILL A MAN BE A MURDERER, KILL A THOUSAND BE A CONQUEROR, KILL EVERYONE BE A GOD ! -
Well, actually, the actual player makes a big difference to the end quality as well.
For example, read a few posts of former Apex DVD owners who have upgraded to a better player...
Or another example, try viewing a VCD on your PC with WMP with and without hardware acceleration. A little bit of filtering goes a long way...
The NAPA from memory was plagued with a number of problems including stuttering playback on apparently completely compliant VCDs...
Regards.Michael Tam
Mercury Playback Engine + CUDA + Premiere
By x2x3x2 in forum Video ConversionReplies: 3Last Post: 10th Nov 2010, 21:29 -
By x2x3x2 in forum EditingReplies: 0Last Post: 9th Nov 2010, 23:32 -
Best HDTV for 200 bucks??
By sandman423 in forum DVB / IPTVReplies: 19Last Post: 29th May 2009, 13:23 -
Looking For A Decent Camcorder Under 200$
By DJboutit in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 7Last Post: 5th May 2009, 11:13 -
LG DAT-200
By TCEkryten in forum DVD & Blu-ray PlayersReplies: 7Last Post: 24th May 2007, 10:26
