I have a widescreen TV and when I create an SVCD with DVD2SVCD and of course using a wide screen movie, I get the black bars on my TV. I notice that the only options are to create 4:3 without borders or 16:9 with borders added (Both of them encoded as 4:3). Is there any way to get 16:9 without borders? Any help would be greatly appreciated.
Parallon![]()
if you're gonna watch the movie on a widescreen TV (HDTV??)
then your OUTPUT VIDEO should be 16:9 DISPLAY NTSC, regardless of what the SOURCE DVD aspect ratio is, which you enter in advanced tab in tmpgenc (either 16:9 or 4:3 525 line NTSC, depending on what dvd2avi's info box tells you)
i'm assuming you have NTSC DVD...and watching on NTSC TV -
Is it possible to modify the settings within DVD2SVCD? I realize that this program is controlled by a batch program, and I have looked around through various files trying to find out where this can be accomplished. I would really hate to have to do each of the associated programs individually.
Parallon -
I am using DVD2SVCD with CCE and it does not let me encode output to anything but 4:3. This is OK because a large number of players cannot properly play 16:9 flagged video for SVCD (my apex cannot). The 16:9 (borders added; encoded as 4:3) option will give the movie the correct aspect on a standard TV but I have a widescreen TV so I set DVD2SVCD to encode 4:3 (No borders, encoded as 4:3). This will stretch out to the correct aspect when viewed on widescreen TV. The only drawback is that it will not play at the proper aspect on the PC.
Thanks "Freak".
I didn't think about that. I will give it a try and let you know of the outcome.
Parallon -
Hey DigiFreak, did I ever tell you that you are my hero? I tried it last night with just a single chapter so that I wouldn't waste 6-7 hours for nothing. Everything is great, and also where my TV would only give me 2 format options, now I have the full five options back again.
Thanks again,
Parallon
aspect ratio
By devdev in forum Video ConversionReplies: 5Last Post: 19th Apr 2012, 17:31 -
Aspect Ratio
By jackowens in forum Video ConversionReplies: 2Last Post: 18th Mar 2009, 17:40 -
Aspect Ratio
By thesuperhemanshow in forum EditingReplies: 0Last Post: 5th Jan 2009, 16:36 -
Aspect Ratio
By mistycat in forum Video ConversionReplies: 8Last Post: 8th Nov 2007, 02:43 -
keep aspect ratio?
By Dunkan21 in forum Authoring (DVD)Replies: 1Last Post: 28th Jul 2007, 13:27
