  1. DVD Decrypter
    DVD2AVI
    TMPGEnc Plus
    ChapterXtractor
    Spruce DVDMaestro
    These are the programs I use in the above order.
    I have successfully copied many dvd's, but the audio in spruce dvdmaestro keeps failing.
    Any ideas.
  2. it is jue to a Inconsistent bitrates in the audio track - the sound track must be a CBR, But it has a couple of seconds of VBR, what u must do to fix this problem is get AC3 machine and re-encode it to a CBR.
    Had this problem my self.
    Get programs from www.doom9.net
    also to use AC3 machine you need bsweet.
    If you need anymore info goto doom9 forum and search for Inconsistent bitrates... cant give u direct link at minute..bedtime
  3. is the audio out of sync? does it keep repeating the same scene over & over? if yes to the both of them U have encountered a seamles branching dvd!! & for this U need to rip the dvd to the drive then use ifoedit & remove the seamless branching in the vob extras, create new ifo's & choose your languages then use dvd2avi to demux the ac3 sound track from the new vob set... mind this is how I done it coz I was sick of having hassles.
    Kev!
  4. it is definetely this problem about the inconsistant bitrates ..
    http://forum.doom9.org/showthread.php?s=01e8563f85b7d4c8268bd37122ef42d0&threadid=3129...stent+bitrates
    scroll down and follow "timekills" guide.
