I have a few AVI files that are Div3 and AC3 for audio, I used GSpot to veirfy this. I'm trying to convert the file to MPEG for a VCD burn.
When I use VirtualDub to save the audio to a WAV file, I get a WAV file with "jumps" in it. When I listen very close, the file jumps and skips every couple of seconds.
This 'jump' causes the video output to also jump after I merge / convert the video files with tMPGEnc. At first I thought that the video problem might have something to do with the TMPGEnc conversion. After I went back and listened to the audio wave file, I heard the sound skipping at the same time the MPEG video was having problems.
The skips don't existing in the source AVI file. How can I get a clean video source from VirtualDub? Is there an AC3 codec I can load that will allow me to just use TMGEnc to convert the AVI to MPEG? The AC3 decoder is for DirectShow, it isn't really a full audeo decoder for ACE.
I'm doing the conversion on a Windows XP system, 512M of memory, AMD 1800 CPU and 15G free disk space.
Hopefully somebody has had some experience tweaking VirtualDub or some other utility for WAV conversion.
Thanks,
1000Watts
decode 5.1 matrix surround wav file to 6 mono wav files
By Zerrax in forum AudioReplies: 2Last Post: 24th Nov 2013, 07:39 -
AC3 to WAV = Wav has no audio??
By RobV in forum AudioReplies: 5Last Post: 31st May 2010, 15:26 -
Encoding wav file to ac3 specification
By gouletjo in forum Authoring (DVD)Replies: 1Last Post: 15th Feb 2010, 22:40 -
5.1 Wav to AC3
By markjwiggins in forum ffmpegX general discussionReplies: 0Last Post: 21st Dec 2007, 14:44 -
Hiss removal from AC3 file without converting it to WAV?
By Turbo Sensonic in forum AudioReplies: 21Last Post: 7th Jul 2007, 06:18
