Hi All. Something happen to my pc and i dont know why.
I capture some shows from tv with virtual dub to compress
to svcd and everything worked fine until i had to format my
hd and now i have a problem.
When im recoring on VD i listen to the sound but no sound
is recorded.
Can anyone help. Please![]()
Results 1 to 15 of 15
People help me out here.
This is strange.
WinDVR records sound but AVI_IO and Virtual Dub dont and i want to record in AVI format.
Dam, dont know what to do.
Someone, please help. -
Which HD did you format - was it the windows drive/partition? If so, the some of your setting might now be default.
If you right click the volume icon on the task bar, you should be able to see the volume controls. Is record control set to 'Line In' and at half volume?
Rob -
the volume controls are normal.
The sound recorded with windvr is fine bit windvr dont records
avi files. -
And under the audio tab of VD, you've got full processing, AVI audio, no conversion and no compression?
Rob -
sounds like u got a prob jimbros m8, fixed it yet? feel free to write how u fixed it n stuff then m8...i need sum help too, not wif same prob but maybe in future...
dam this is getting anoying.
Power VCR - Records sound Fine
Win VCD - Records Sound Fine
Premiere 6.5 - Records Sound Fine
Virtual Dub - NO SOUND RECORDED
AVI_IO - NO SOUND RECORDED
Just tested with WDM Drivers 1.08, 1.16, 1.19 with no change.
Changed sound driver and no change.
dam, have to return some tapes next weekend and i need to
capture them before that. -
My system is realy strange.
just instaled the new uiVCD version and now
Virtual dub and AVI_IO records sound fine.
Thanks All -
Can u tell me what u mean by installing new version of uiVCD.
I have the same problem, no sound on VD.Never too old to learn -
Today i download iuVCR v4.0.0.230 and after instaling, configuring
it and testing it (didnt like) i tested again Virtual Dub and it had sound. -
Please tell me where I can download uivcr or is it uivcd.
ThanksNever too old to learn -
i presume cables are all o.k.
your not recording in 5.1 by chance -
By any chance are you using a version of Windows that's pre 98-SE? If so, you'll need to do some dicking around that I haven't quite figured out much. All I know is that you can fix it by changing crossbar settings, but that only works with native WDM programs (VirtualDub, etc. are VFW). I have the same problem with my TV Wonder VE running under 98 first edition (second edition fks up my comp, so it's out of the question). Is there anybody with any experience with this problem?
The cables are OK.
I can listen to the audio when VD is running. When I tried to encode with TMPGENC, it couldn't find the audio file.
AM using W2K and not recording in 5.1, just plain stereo.
Any suggestions.Never too old to learn
Capturing problem
By Phoenix 37 in forum Capturing and VCRReplies: 4Last Post: 18th Jun 2011, 18:09 -
Firewire HD capturing Problem
By superdud1400 in forum Capturing and VCRReplies: 8Last Post: 8th May 2008, 10:03 -
Having problem(s) with my Capturing device
By Adoll in forum Capturing and VCRReplies: 0Last Post: 5th Apr 2008, 12:58 -
DV capturing problem
By BMR in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 25th Sep 2007, 17:19 -
Capturing Problem.
By rowie4life in forum Capturing and VCRReplies: 1Last Post: 20th Aug 2007, 09:33
