  1. I have the Halo 2 trailer which I would like to convert to MPEG-2 so I can write it to a S-VCD and play it on my DVD player. I have tried renaming the .wmv file extention to .asf, but it still will not work. The Halo 2 trailer requires the Windows Media Player 9 codec (I'm pretty sure). Does anyone know how to convert Media Player 9 .wmv format to MPEG-2?
    Thx in advance--
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    good luck -- try following the same method as for converting realmedia as that may work
  3. Could I take a JPEG of each frame, then put those together to make MJPEG, and then convert that to MPEG-2 with TMPGEnc?
    The only thing is, I don't know how to view the video frame by frame.
