I have downloaded quite a few movies from kazaa but when i come to play them they don't work, i have tryed using Media player, divx player with the xvid add on and also power dvd. The file says its a .avi but won't play, they seem to be about 700 - 800mb and some of them do work but the other give me a error message saying
Divx "The file that you are attempting to open does not appear to be a divx file type"
WMP "Cannot play back the file. The format is not supported"
Power dvd, this just does nothing.
Please help because i'm wasting loads of time download films that don't seem to work.![]()
Download Nimo Codec Pack:
http://www.btinternet.com/~nimosiro/"Today is only yesterdays tomorrow" -
AnonymousGuest
Try this also:
http://www.geocities.com/cplarosa/movieid/
Unzip it to a folder then drag and drop the movie file to movieidw.exe.
It will then pop up a "NotePad" window with all of the specs of the file.
If it really is a movie type of file (avi, mpeg, asf etc...) it will tell you.
After that you can then start searching for answers as to why it doesn't play.
GoodLuck! -
There seem to be plenty of fake movies on Kazaa and other P2P networks at the moment. Search the forums on how to test the validity of a movie whilst it is downloading so that you can cancel the fakes before wasting hours waiting for them to fill up your HD.Originally Posted by SexySte
Best way to play Downloaded 3D Movies
By mafioso22 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 12th Feb 2012, 13:22 -
What Program will convert both DVD and Downloaded Movies ?
By JMGrande in forum Newbie / General discussionsReplies: 1Last Post: 13th Oct 2009, 16:46 -
Viewing downloaded movies
By orangekrush in forum Newbie / General discussionsReplies: 8Last Post: 16th Dec 2008, 04:10 -
How will HDCP affect downloaded movies?
By EatMoreChickens in forum DVD & Blu-ray PlayersReplies: 5Last Post: 29th Jan 2008, 10:31 -
storeing my downloaded movies as data
By dgavob in forum Newbie / General discussionsReplies: 20Last Post: 10th Nov 2007, 01:21
