  1. ok, i started the whole process and used the guide and set all the settings right and i do have cce2.5, but after its all done i think i try to open in windows media player or real player and it says something about cce and has a code, and i cant open with cce so what am i supposed to do
  2. "but after its all done i think i try to open in windows media player or real player and it says something about cce and has a code, and i cant open with cce so what am i supposed to do"
    Im a little confused here.. Im assuming you are trying to open the mpeg file via media player??? if so make sure windvd is installed on your system giving you the codecs to decode mpeg2 files.
