DAM I HATE HOW PEOPLE FUK WIT POST W/O ASKING??!?!?Any ways.... like the last post... i am tryin to back up a copy that i bought .... i ran it thru ifoedit and got it down to 4.3 but when i try to burn it wit primo it keeps comin back with error..... this is the same thing tht happen with my monster inc and i still havent found out the prob..... can anyone help me with this??????? is it a ifoedit prob or is it a primo problem???????
it because u have stripped things out of the vob files what are supposed to be there according to the video_ts.ifo and primo looks at this file before it burns it. What you can do if you are confident that the dvd will work after you burn it to disk, is use nearo in DVD ISO/UDF mode. That will burn it without checking. Or if you still want to use primo, Create new VIDEO_TS.IFO and VTS_01_01.IFO files using Ifoedit.
well i use the ifoedit guide that this person posted.... i ripped everything from the dvd and then did like the guide said........ read it and tell me if it was on point or not
http://www.vcdhelp.com/forum/viewtopic.php?p=315500&highlight=#315500 -
before you burn it , load video ts ifo , in ifoedit and click get vts sectors.
ok.... but what should that do ?????? and do i need to do anything after that?????
No just , get vts sectors from vts 1 ifo and video ts ifo, it should correct them, then just burn.
YEP.... THANKS.... THAT WORKED..... now one more question...... when i tried to chge the files into iso (my video_ts folder) it wont do it..... so how do i chge my video folder into iso file???????????
i have spiderman season 1-5 and its .avi. can i burn each season on dvd?
By dizzlenizzle87 in forum Newbie / General discussionsReplies: 7Last Post: 8th Jun 2007, 00:23
