I'm running flaskmpeg 0.6 and my o/s is win2000 (service pack3). I have copied movies sucessfully before with win98 so I don't know if it is my new o/s, but flask will only produce an mpeg no longer than 121 mins no matter what time/length is entered. Any Ideas??
Hmmm... curious.
I use WinXP Home and I can convert movies longer than 2 hours with no problems...
My suggestion? I've had odd FlaskMPEG problems before (usually after upgrading the version) and usually it gets solved by completely uninstalling it (including deleting the entire folder) and then reinstalling it.
While you're at it, if you are making VCDs, I strongly suggest the "subtitle fixed" version of FlaskMPEG 0.6 available at doom9.org There have been recently released new 0.7.x versions of Flask. I have not tested those versions as yet.
Regards.Michael Tam
w: Morsels of Evidence -
I have tested them. they seem to be much more stable releases. And some of the new features make it worth the upgrade.
DV won't play correctly anymore.
By xtremeD63 in forum Software PlayingReplies: 52Last Post: 9th Apr 2011, 13:08 -
DV video clip won't play anymore
By cajustse in forum Newbie / General discussionsReplies: 3Last Post: 11th Jun 2009, 14:57 -
How to burn a 157 mins. video on a 120 mins. dvd
By Gerald Sr. in forum Authoring (DVD)Replies: 2Last Post: 20th Jan 2008, 02:19 -
LG DVD-R 4.7GB/ 120 mins. 1-8X DVD Disc with 2:28.52 movie
By Gerald Sr. in forum Authoring (DVD)Replies: 4Last Post: 12th Nov 2007, 16:09 -
Help! My Dvd Player Won't Mp3's Anymore
By Just8 in forum DVD & Blu-ray PlayersReplies: 4Last Post: 1st Jul 2007, 23:08
