Well, let's me explain my case, I have a DC10 PLUS, a PAL VCR (I'm from Brazil :P ), a conversor PAL2NTSC, Ulead DVD Workshop, all under Windows XP. All works fine, just the audio is out of sync. I changed my Sound Board, before was Onboard VIA from my mainboard SOYO SY-K7VTA Pro, now it's a Creative Sound Blaster AWE64, I also have tried to reduce the FPS to 25, the both tricks didn't solved my problem.
So, now I really don't have more hidden cards, what can I do? I'll be very thankful if aomebody can helpme.![]()
I had audio sync problems before then i heard somewere that if u burn at a high speeds u get sync problems
now i burn at 8x instead of 16x and i never had another sync problem -
Chopy,
The problem is on capture, I noted the audio is late, which eliminate my theory of dropped frames have the fault of async. The capture start sync, after +- 1 minute the async starts... becoming worst each minute... In this Forum I've found a guy that have Ulead DVD Workshop and never had Audio Sync Problems...
Chopy, do you use Ulead DVD Workshop? Is the problem of audio sync happens just on playback on the Ulead DVD Workshop? Does this audio async problem become smoke when you have the video burned in DVD or VCD??
I'll be ver thamkful if you replyme,
Hugs
Elizeu S Oliveira Filho
Brazil -
yes i use ulead dvd workshop
no my audio problem did not happen in unlead dvd workshop
and yes it was present when it was burnt
Problems with sync with subtitles workshop
By Shanny9 in forum SubtitleReplies: 4Last Post: 11th Feb 2012, 06:58 -
Does anybody have Ulead DVD Workshop SE 1.21?
By OS_Man in forum Authoring (DVD)Replies: 5Last Post: 21st Sep 2010, 03:04 -
Subtitle Workshop - audio sync issues/crashing
By ecc in forum SubtitleReplies: 3Last Post: 30th Mar 2009, 23:59 -
Ulead DVD Workshop 2 with Vista?
By SCDVD in forum Newbie / General discussionsReplies: 2Last Post: 17th Feb 2008, 03:48 -
Ulead DVD Workshop 2 error
By SEE_Studios in forum Newbie / General discussionsReplies: 21Last Post: 4th Jan 2008, 03:55
