I use both asf recorder and streambox vcr. Using asf recorder. I have the following error: 404 object not found. But the file was still there. Using streambox vcd. I have the following error: Time Out. The URL of the asf file is like this (example: mms://111.111.111/asf movie/lovmovie.asf)
HELP PLEASE ANYBODY JUST ANYBODY HELP ME PLEASE.
if streambox and asfrecorder dont work, your last hope is www.metaproducts.com Offline Explorer Pro or Enterprise version... just drop that link into the download bar and hit enter or download... if that doesn't work then the stream is too well protected...
although, you could also try:
HiDownload
SDP
or other software at www.souxin.com -
Thanks a lot for your help. I have managed to download the files to my computer.
Saving/capture solutions for saving off (extending) DVR
By ET3D in forum Newbie / General discussionsReplies: 1Last Post: 28th Oct 2011, 19:13 -
Problems with Movie maker saving to dv-avi
By jbitakis in forum Video ConversionReplies: 7Last Post: 15th Sep 2010, 10:19 -
Do Movie Maker or Virtualdub re-encode DV-AVI when saving? Quality concern?
By sdineen in forum Newbie / General discussionsReplies: 9Last Post: 18th Jul 2009, 22:47 -
Saving Movie
By achakzai in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 16th Jun 2008, 04:27 -
need help saving this flash file to my computer please
By kcaJoC in forum Newbie / General discussionsReplies: 3Last Post: 24th Sep 2007, 22:48
