I made a Svcd out of a movie, but now the voices won't fit to the motion of the acteur's mouths. Now i saw that the AC3 File has a delay of -78ms. So i tried to encode with BeSweet and Headac3he and entered -78 as Delay, but its still not syncron. What should i do?
try using virtualdub as a single wav file, then what i do is use dvdavi2 and process wav that i just did with virtualdb, then you can set the delay to 0 that takes care of it for me when i convert to mpeg with tmpge, besweet is a pain to use
I used a DVD as source, not an avi. But maybe if i encode the AC3 to a Wave i can use that method.
yes try that, it should solve your problem, i had the same issue
I can't find dvdavi2, Do you mean DVD2Avi? If yes how to use it? if tried but I can#t find the option to set the delay.
in tmpgenc, under the source range filter, there is an audio skew function where you can set audio delay in milliseconds (ms)
MiniDV Video & Audio Problem - Corrupted, Detiriorated, Missing Audio
By 4truce in forum Capturing and VCRReplies: 14Last Post: 4th Aug 2011, 07:36 -
How to combine video with audio file and replace audio with video files ?
By designbuyers in forum Newbie / General discussionsReplies: 2Last Post: 8th Feb 2009, 12:12 -
Pass additional arguments (async)?
By SalsaShark in forum ffmpegX general discussionReplies: 0Last Post: 25th Jun 2008, 21:42 -
Syncing spearate audio/video: Better to stretch/shrink video than audio?
By stantheman1976 in forum EditingReplies: 15Last Post: 16th Jan 2008, 05:14 -
Converting an AVI video with AC3 audio to an AVI video with MP3 audio
By rijulHKG in forum AudioReplies: 1Last Post: 15th Jul 2007, 01:23
