Hi! Can anyone help me play my vcd's on my lap top? One works automatically but most do not. when i tried to open them using the advice given, i accidentally opened it with 'movie player' (which is bad!) instead of media player and my comp will not let me open them with anything else. The icons for the mpeg, (or is it mgav?) files now all have the movie player logo even though i have deleted it from my computer. Can anyone offer me some advice as im living in south korea and have no entertainment after teaching on week days except for korean tv. please help, many thanks, dean crawford!
Highlight the file you want to open by single clicking on it with the left mouse button.
Then hold down the shift key and right click on the file.
This should bring up a data box with various options on, the first one is OPEN - ignore that.
The second one should say OPEN WITH.
Select this option and it brings up all the different programmes for you.
Select the programme you want to open with ( media player in this case) and follow the prompts. It will reassign the correct icon to your files automatically
Hint: If you are ever unsure that you are selecting the correct programme to open any given file, uncheck the tickbox that says "always use this programme to open" (or words to that effect).
Once you have the correct programme opening the correct files , you can always follow this through again and check the tickbox.
Hope this isn't too complicated for you, it is a lot esier to do, than it is to describe how to do it.
an honest look at TMPGEnc Video Mastering Works 5
By deadrats in forum EditingReplies: 8Last Post: 19th May 2011, 19:02 -
I can't get an .flv, or an .swf to play on my site
By drew68 in forum Video Streaming DownloadingReplies: 9Last Post: 14th Dec 2010, 14:00 -
an honest look at gpu accelerated encoding
By deadrats in forum Video ConversionReplies: 2Last Post: 22nd Aug 2010, 20:39 -
an honest look at piracy...
By deadrats in forum Off topicReplies: 27Last Post: 24th Oct 2008, 23:50 -
Looking for honest opinions
By xtremegamerx in forum Newbie / General discussionsReplies: 15Last Post: 7th Jan 2008, 20:36
