i know this has been posted b4...i have a slow speed ripping with Smartripper..
i have a 16x toshiba 256 ram amd-750mhz.
the speed goes about 2x max....
can someone tell me why =0
thanks
if you know this was posted before, why didn't you read or contribute to that post?
1) Set drives to DMA (Dont ask how, search for the answer via here, the net and usegroups)
2) Use a UDAM IDE cable
Mine jumped from 1.6X - 2.0X max to 2.5X - 6.5x max
Good luck
<hr>
Well vested in the following: Pinnical DC-10+, TMPGEnc, AVI_IO, VirtualDub, Flask, BBMpeg, SmartRipper, DVD2AVI
<hr> -
SeezarGuest
The toshiba sd-m1502 dvd drive is limited to 2X dvd video reading within the firmware. Thats why you cant rip any higer than 2X.
Wrong m2v file length with SmartRipper
By kenj in forum DVD RippingReplies: 9Last Post: 11th Jul 2010, 18:44 -
AutoGK, DVDShrink, SmartRipper won't recognize stream language/info
By takearushfan in forum AudioReplies: 5Last Post: 26th Sep 2009, 20:21 -
SmartRipper -- question about "Search Intensity" setting
By Dr.Rock in forum DVD RippingReplies: 1Last Post: 30th Dec 2008, 14:26
