I'm looking for progressive scan Component Video cable that use for Progressive from DVD to HDTV with Y/PB/PR.
i think there are difference between Y/PB/PR and Y/CB/CR. I think the he letter with P is progressive scan and the letter with C is standard color
i've been looking for Y/PB/PR but most of cables are Y/CB/CR.
Does Monstercable series 3 Component video cable(MV3CV-4M) has Y/PB/PR?
There are two forms of component video Y/Pb/Pr and Y/Cb/Cr.
Y/Pb/Pr, used most often with progressive can video devices progressive scan video devices. Separates a video signal into three separate channels using progressive scan (non-interlaced). These channels reduce interference to produce better picture quality. This format can handle 30K of information.
Y/Cb/Cr, used most often with standard interlaced scan video devices. Separates a video signal into three separate channels for better picture quality. This format can handle 15K of information.
there is also professional level of component such as on Beta SP .
the cables used for either Y/Pb/Pr or Y/Cb/Cr are the same though in fact there are 5 wire type Y/Pb/Pr seen also (when a combo RGBHV / Y/Pb/Pr innput is used).
Cable length component
By Michielvsb in forum ComputerReplies: 4Last Post: 22nd Oct 2011, 08:07 -
Component cable
By alintatoc in forum Off topicReplies: 3Last Post: 23rd Jan 2010, 09:20 -
RGBHV, VGA, component cable confusion
By Asterra in forum Newbie / General discussionsReplies: 3Last Post: 9th Aug 2009, 19:58 -
Capturing Xbox 360 Video Using Component HD AV Cable
By FrankieB in forum Capturing and VCRReplies: 2Last Post: 18th Feb 2009, 12:21 -
DVI/Component cable
By ajcstr in forum DVB / IPTVReplies: 9Last Post: 16th Oct 2008, 05:25
