Smart Ripper does not seem to rip the main movie,just one of the features. How can I ensure it rips the correct bit? :P
carpe diem maņana
you can't....i believe smartripper assumes that the largest vob sets is the main movie (i'm not sure...but that's wut it seems)
i.e. pearl harbor DVD disc 2, smartripper assumed one of the behind-the-scenes was the main movie file prolly because it was bigger than the movie file. -
i think u can select what part u want to rip.U have to go stream processing,then tick enable stream processing,then select the streams u want to rip.
Would it be of any use using another piece of ripping software?
carpe diem maņana -
I have never seen Smartripper make a mistake selecting the main movie. It's information box tells you the length of the movie it has selected,if you know the length of the movie,select that length. Why would anyone want to rip Pearl harbor. It is without doubt the worst movie ever made. They turned one of the greatest events in American history into a bad,trite,love story.
Are you sure you didn't mean greatest disasters.
I love that movie by the way.
Originally Posted by wulf109
btw..i've seen worse movies -
Thanks for the help. I found the right files to rip in the end. (preferred Tora Tora Tora myself)
carpe diem maņana
Question about a feature on my new TV
By hardy in forum Off topicReplies: 2Last Post: 13th Dec 2010, 18:08 -
Backup main movie from DVD9 to DVD5 with main & chapter menu's.
By ChibiTomo in forum User guidesReplies: 18Last Post: 18th Jan 2010, 19:27 -
Leave Menu, Change Main Feature
By Mukenio in forum Newbie / General discussionsReplies: 10Last Post: 4th Jun 2009, 22:29 -
How to full backup (no encoding) BR main movie, main audio with subtitles ?
By meico1234 in forum Blu-ray RippingReplies: 2Last Post: 2nd Feb 2009, 03:37 -
possible feature
By magenta2007 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 8th Oct 2007, 15:40
