  1. i was wondering how to configure winDVD to better take images....
    when i use "P" to take still images, the resolution was all screwed up and not in the correct aspect ratio of the movie itself....also, the image wasn't as clear as i hoped...
    any helP?
    Oct 2002
    From the last time I used WinDVD I found that it only captures the images like you using an anamorphic display, I found that Power DVD not only lets you pick the resolution you want to save it, but also has a much nicer output.
