Hi. I just recently made a vcd and when i played it on dvd player (which can definitely play vcds because another one i have works) the audio is garbled, low, and makes a swishing bubbling sound. When i previewed the vcd using Windows Player is sounded just fine. It seems to only make the garbling sound when its played on the dvd player. I used the latest version (demo) of nero and using TMPGEnc to encode the file. Any suggestions? Thanks
....ooookkkkkaaaaay. I switched the audio on the dvd player from coming from the left and right side to just the right or left side(speakers) and it worked fine. Good thing i don't have an elaborate speaker system or else this one speaker thing would be a problem. Though...if anyone knows how to keep both speakers on and get rid of the jittering I would be grateful
No Audio In Encore/Bad Aspect Ratio/Bad Files/Bad ISO/Bad Everything
By koberulz in forum Newbie / General discussionsReplies: 35Last Post: 24th Jan 2010, 04:48 -
Fixing bad resampled DVD audio
By silverwolf0 in forum Newbie / General discussionsReplies: 3Last Post: 6th Jun 2009, 10:59 -
nero with bad audio quality?
By mai_hnf in forum Authoring (VCD/SVCD)Replies: 1Last Post: 3rd Sep 2007, 04:07 -
bad audio frame
By demonwarrior in forum Newbie / General discussionsReplies: 1Last Post: 12th Jun 2007, 14:37 -
Bad Audio problems
By Shaba1 in forum Newbie / General discussionsReplies: 4Last Post: 23rd May 2007, 00:02
