  1. OK I burned a movie from kazaa onto a dvd only to find out it was PAL and didn't play in my player. however i deleted it from my computer to save space after putting it on a dvd, so now i need to get it back into tmpgenc but when i go to open it out of my F drive i cannot find any files under the two main ones it brings up, MYdvd, and when i bring up all files in there it brings up My DVD and then when applied it says "unsupported" and the other main folder is videots and when i go to all files it brings up a list of files all named vts and video with different ending numbers if anyone can help me plaease do. THANKS
  2. Renegade gll99's Avatar
    May 2002
    Canadian Tundra
    Is there at least one or more large ones with an ending of "VOB"
    There's not much to do but then I can't do much anyway.
  3. Member wulf109's Avatar
    Jul 2002
    The vob files should be in directory named VIDEO_TS on the DVD disk,they really have to be. You could try ripping the DVD,I've ripped DVD-R's back to the HD. I don't believe it's possible to encode directly from the disk,you need to get the vob files back on your HD.
  4. OK thanks i found the big one sent it to my documents and opened it in tmpgenc set all the settings i think and now all i gotta do is wait for it to finish encoding and then burn it right
