I do not know what to do...
I am using a WinFast A250 Ultra TD - MyVIVO Edition Video Card (nVidia Ti 4600, 128 MB S-Video And Composite In And Out).
I have a Dish Player where I have recorded a whole bunch of TV shows that I like that I want to transfer to my computer with the absolute best image quality... but I don't want them to be 1 GB files either, hehe!
Anyways... I am a newbie, but here is what I have done so far...
I am not having any trouble with getting the video and sound in... I am using the latest version of VirtualDub and I am encoding with Divx 5.02.
Here is a link to a test file I did. To me, it just doesn't look fantastic... I think I am losing frames or something... according to the settings, I am getting 15 frames per second... and if I modify it, I lose frames or it gets choppy? Can someone download the test file (about 600 KB), take a look, and let me know what I can do to improve the quality?
http://www.cdsend.com/testing04.avi
UPDATE!!! HERE IS MY LATEST TEST... AND I CAN DEFINITELY SEE SOME KIND OF FRAME DROPPAGE OR SOMETHING WEIRD... PLEASE HELP!!!
http://www.cdsend.com/testing05.avi (ABOUT 3 MB)
Should I lock the video stream to audio? Is this a good thing or a bad thing? How can I make it look less choppy? Or... is it fine and am I just going crazy? At this rate... I can get a 30 minute show (20 - 24 minutes without comercials... to around 100 MB).
I am posting some of my VirtualDub settings at the bottom...
Thanks!
Jay
Capturing
Audio Compression To MPEG Layer-3
Verify Audio Volume
Video Format To 320 x 240 At UYVY
Video Source To S-Video
Video Compression To Divx 5.0.2 Codec
Enable Cropping
Cropping Bounds Should Be X1 10 X2 10 Y1 2 Or 30 Y2 2 Or 30
Set Capture File
Set Stop Conditions 1830 Or 3660
Editing
Set Compression To Divx 5.0.2 Codec
The problem is most likely that you are tryign to capture the audio to MP3. Divx compression already eats cpu cycles, Unless you have a very, very fast PC, Compressing to divx and mp3 in realtime doesn't work to well. As a test, try a different audio format.
Hehe... I have a Athlon XP 2200 system with 512 MB PC2700 SDRAM... I just tried using Microsoft's Mpeg4 Codec Version 2... is this correct? Anyways... it works quite well... any thoughts?
Also, what is the common codec for audio?
Jay -
try to use wav that not requery cpu only disk and sice you caputere to divx the disk is not the problem
Virtualdub VCR capture no dropped frames but 5400 inserted frames in 1 hour
By suloku in forum Capturing and VCRReplies: 12Last Post: 17th Aug 2011, 23:33 -
need help unblending previously blended frames rather than dropping frames
By BilboFett in forum Video ConversionReplies: 15Last Post: 12th May 2011, 22:15 -
mencoder: seeking to frames (or cropping start frames)
By manchurian_candidate in forum LinuxReplies: 3Last Post: 13th Dec 2010, 09:53 -
HDTV to DVD using DGIndex/AviSynth losing frames
By gadgetguy in forum Video ConversionReplies: 13Last Post: 3rd Sep 2008, 17:12 -
inserted frames without dropped frames in VirtualDub capturing VHS
By whschlebaum in forum Capturing and VCRReplies: 0Last Post: 23rd Aug 2007, 21:59
