If i plan on putting subtitles and chapters in my movie, do i need to set the right setting on smartripper when i rip my movie?
If you just rip the "main movie" you should get all the sub streams. If you know which one it is that you want, SmartRipper will also do stream copies so you can pick the subtitle stream you want and discard the rest. Hope it helps!!
just make sure you copy the .ifo file
both vobsub/vdub and flaskmpeg methods require the .ifo file....
Simple Question re Premiere CS5
By jkholmes in forum Newbie / General discussionsReplies: 10Last Post: 3rd Mar 2011, 21:50 -
AviAddXSubs simple question (hopefully!)
By vladman2nd in forum SubtitleReplies: 1Last Post: 8th Jul 2008, 01:01 -
Simple Mplayer Question
By Maikeru-sama in forum Newbie / General discussionsReplies: 6Last Post: 29th May 2008, 21:10 -
Embarassingly simple capture question
By eclipse95 in forum Capturing and VCRReplies: 5Last Post: 16th Nov 2007, 13:12 -
Simple Question: True or False?
By jcm0320 in forum Capturing and VCRReplies: 10Last Post: 23rd Aug 2007, 22:33
