Planning on backing up my movies, music and data. Here is a link to the blank dvd's that I am planning on purchasing. Let me know what you guys think.
http://www.allmediaoutlet.com/DVD-RCOMBO-princo.html
Princo's are great... The eralier Gen1 and 2 had some problems with the outer edge recoring, but since then it's been fixed. They burn great.
DEPENDS!!!!
Which dvd writer you have?
I have a Sony DRU-500A with 1.0d firmware, Nero 5.9.9.17, using DVD Decrypter, and IFOEdit to rip DVD movies.
I bought Princo DVD-R 1X Gen4 at the following site:
http://www.allmediaoutlet.com/P-DVDR-4.7-GENPrinco.html
with the white glossy top and could not get pass the 5% burning mark. Wasted 5 out of 5 DVD-Rs.
After that I'm using Ritek DVD-R 1X at the following site: WORKS GREAT BUT ONLY 1X
http://www.shop4tech.com/user.htm?go=view_item&id=242&cata=1&s_cata=88
After that I'm using Meritline DVD-R TRUE 2X at the following site: A LITTLE MORE PRICEY, BUT SAVE TIME
http://meritline.com/mer47dvmed2x1.html -
Originally Posted by g00kster
Your Nero was 5.9.9.17.0 (first version) or 5.9.9.17.1 (releast 11.6) ?
Could you please post Manufacturer ID (using ADVDInfo) if you still have some media ?
And if disk have some number on it, could you please post it too ?
I am asking becaouse I was able to burn Princo from Meritline.com but I had only 1 pc and Allmediaoutlet.com are cheaper. (BTW, data size was 3.95GB).
Thanks -
I bought a 100 bundle of the Pringo white DVD-RWs on ebay several months ago when I first started this DVD ripping journey. I've had very inconsistent results with them. Part of my problem may come from the fact that the 1st two Pioneer burners I bought from ESBuy would not work and I used 30 or 40 of the disks trying to get them to work.
I finally bit the bullet and bought a firewire enclosure Pioneer burner so I could use it with my faster processor laptop. The disks I had tried I erased and those are the ones for the most part that have caused problems.
I've had movies that wouldn't play past 2/3s of the way through or would not let you skip ahead to chapters. Also had pauses later in the disk with the movie resuming after a 5 to 10 second pause.
I have bought some gold private-label DVD-R from ESBuy for about $2 each that I am going to use for movies I want to keep for a really long time. I understand the white face disks have a shorter shelf life. Don't know if that is true or not.
Lynnsabcs
Samsung DVD-HR753 DVD and HDD recorder rejected all my blank DVD
By undangltn in forum DVD & Blu-ray RecordersReplies: 1Last Post: 14th Mar 2010, 12:34 -
Good Affortable Blu-Ray Blank Discs
By Digitalskull in forum MediaReplies: 1Last Post: 28th Sep 2009, 21:51 -
Good place to buy blank BD-R's?
By markw in forum MediaReplies: 1Last Post: 18th Apr 2009, 23:11 -
Is the Hp DVD740 a good choice for basic DVD burning
By EthansMom1030 in forum DVD & Blu-ray WritersReplies: 4Last Post: 11th Feb 2009, 09:03 -
Good ? blank dvd
By pacificdon in forum Newbie / General discussionsReplies: 9Last Post: 1st Apr 2008, 14:26
