I have just upgraded to Pentium IV and the ATI's AIW Hercules (Radeon 8500)
Card. So far, with the AIW 128 Rage Card, there used to be a Multimedia
Capture Drive besides the Rage Theatre Capture Driver and VirtualDub
accepted it for capture operation. When I tried to open VirtualDub after
installing the Radeon 8500, VirtualDub crashed.
One could capture with ATI's capture software but that saves the file
directly in MPEG-2 format with mpg extension. With VirtualDub AVI file, I
was encoding it into mpg format using Tsunami MPEG Encoder. And those TMPEG
encoded files were acceptable to Roxio for burning into a VCD or SuperVCD.
Will the ATI MMC captured and mpg encoded files be directly usable for
making a VCD or SuperVCD? Or would they need some kind of conversion to make
them usable for burning into a VCD/ SuperVCD? If they can be directly used,
with which software Nero Ahead or Roxio WinOnCD?
The Radeon 8500 is also unable to scan all the cable TV channels in India.
Any solution for this? Of course I am using the driver which came with the
Radeon 8500 Card on a CD. Are there later versions which have corrected any
of the problems? Which official or rage Underground version would enable me
to use VirtualDub back again?
P. Jayant
Pune, India
Results 1 to 1 of 1
Ati theatre 750 vs theatre 650
By smengy in forum Capturing and VCRReplies: 18Last Post: 25th Aug 2013, 22:10 -
Virtualdub 32bits error: cannot connect to the desired capture driver!
By Cauptain in forum Capturing and VCRReplies: 3Last Post: 21st May 2011, 12:17 -
Ati 600 usb stick and virtualdub capture
By buckethead in forum Capturing and VCRReplies: 4Last Post: 8th Mar 2011, 17:13 -
ATI MMC 8.8 - capture driver not listed in registry?
By justin81 in forum Capturing and VCRReplies: 0Last Post: 21st May 2010, 11:13 -
Resolution Test - BT878 - ATI Rage Theatre - Philips SAA7130
By BrainStorm69 in forum Capturing and VCRReplies: 3Last Post: 23rd Mar 2010, 07:10
