if i was to crop a couple of lines of the top and bottom of a film to make the black bars a little smaller would i also have to crop some off the sides.
Im talking about only taking about 3 - 5 lines off.
If you want to maintain an accurate aspect ratio then you need to take off on the sides too. For example, if you crop 4 off of bottom, crop 2 on each side.
If you are talking about TMPG, provided you choose *Full screen - keep aspect ratio* and the correct source aspect ratio, the cropping filter does not appear to alter in any way the final aspect ratio of the mpeg. You can verify this by choosing a small sample with the source range setting, and doing some drastic cropping! 8)Originally Posted by Haku
I need help with cropping!
By UnD3R0aTh in forum DVD RippingReplies: 23Last Post: 23rd Mar 2010, 02:33 -
Cropping...
By bsuska in forum Video ConversionReplies: 40Last Post: 15th Jul 2009, 16:27 -
cropping
By mwh99 in forum EditingReplies: 2Last Post: 7th Nov 2008, 13:25 -
Cropping DV
By bsuska in forum Newbie / General discussionsReplies: 1Last Post: 13th Feb 2008, 11:31 -
cropping
By exekutive in forum ffmpegX general discussionReplies: 5Last Post: 25th Aug 2007, 01:02
