Can someone help me with this??
Ok, I have ULEAD DVD MOVIE FACTORY.
I want to capture video in PAL format.
When I plug in everything and have the program running, its actually previewing the video just fine.
BUT, when i try to record, about 3 errors show up, and i have to restart because the computer says "your capture card is being used by another program", and it isnt.
It gets really annoying.
So...do I have to capture it as a PAL file, then convert to NTSC, or can I capture in NTSC?
But then again, I dont think that that's the actual problem
Oh yeah, and if it helps knowing, my capture card is winTV.
Thanx!
