Try DVDFab and download streaming video, copy, convert or make Blu-rays,DVDs! Download free trial !
  1. I'm using Tmpg12g with some templates I downloaded from the net but when I'm encoding action sequences the quality drops
    cause of the big blocks on the screen.
    Is there a way of reducing this kind of blockiness?
    Maybe increase the number of motion vectors? Help!
  2. hrm...first of all...what type of template you using (i.e. VCD, XVCD, SVCD, etc..) but if u using VCD or XVCD, try switching to SVCD because it has higher resolution than the first 2 formats i just mentioned...also..try increasing bitrate and set motion search accuracy to "high quality (slow)"
