  1. I am capturing my vhs-c camera movies using my dc30 plus miro capture card,so far the quality is great,when I cut any part of the movie that I don't want I use VirtualDub,then before I "save as avi" I check the compression choices and I have a bunch of codecs to use,if I save using DC30+ codec I have a error,so I use the ohe that works,wich is a "uncompressed RGB" but I have a huge file,like 250mb file turn into a 4G file,can someone advice about other codecs that can be good for this purpose?
    thanks.
    Rigo.F
  2. Select direct stream which will allow you to save the cut video without reencoding-it's kind a like a cut and paste method for video. Depending on the file size and processor speed it still may take awhile to process the cut.
  3. it was in "full processing mode" I'll give a try it to "direct stream".
    thanks for your help.
    Rigo.F
