Hey
Ok, the problem is when I take the VCD that I burned to the DVD player and play it in there. The video comes out perfect but there is no sound. Now if I take the file that I burned into the CD and listen to it on the comp. then everything works, sound and video. Does anyone know what the problem might be?
I took a .wmv file and converted it to .avi and then to .mpeg using TMPGEnc.
Check the audio and see if it is monaural or stereo.
Hello. -
Thank-you for helping
I checked the sound it's set to stereo. One thing I did notice is that when I watch the preview as it's converting there is no sound on the preview either. Is it suppose to be like that or do I need to do something else? They are just a whole bunch of music videos that I want to have so it's not like a big file or anything. -
Take the AVI file and load it into Gold Wave. It should show audio throughout the file. If it does, save it as a wave file, and mux it with your avi file in TMPGEnc, using a template you will be making the VCD with.
Hello.
What is the best virtual surround sound from a motherboard or a sound-card?
By MarcMiller in forum ComputerReplies: 0Last Post: 19th Jan 2012, 22:03 -
3d video with dts sound how to convert to ac3 sound
By fredddiemercury in forum Video ConversionReplies: 4Last Post: 2nd Nov 2011, 15:54 -
Audio Sound File Saved - Canot Hear Sound - Total Recorder
By Teac23 in forum ComputerReplies: 1Last Post: 15th Apr 2011, 15:29 -
Need advice getting rid of buzz sound at end of every word of video sound
By OM2 in forum AudioReplies: 18Last Post: 30th Oct 2010, 12:58 -
DVD LAB : Different sound in different movie (MIXED SOUND): NOT WORKING?
By SteamrollerLive in forum Authoring (DVD)Replies: 2Last Post: 24th Jun 2007, 19:01
