I previously used several programs on my temp PC to convert a compressed DivX to uncompress the audio stream to PCM, then decompress the video stream to MPEG, then finally use a burner program to transfer to videocd. Well, the program to uncompress the audio stream (it's called decompress, it comes with AVI2VCD) somehow doesn't work anymore, it keeps telling me to reinstall DirectX. No matter how many times I reinstall DirectX 7a, it still gives me that BS message. I was just curious if anyone knew of any better decompression program that wouldn't give me this annoying message. Thanks in advance for any replies!
Mew13
If you mean decompressing audio as in converting mp3 audio to PCM wav then try dbPowerAmp. You'll find it in the tools section. WinAmp must also be able to do such a thing. Never tried that one myself.
Regards,
Willem
Divx Compression
By RustyBob in forum Newbie / General discussionsReplies: 1Last Post: 21st Feb 2011, 18:05 -
YT audio compression
By -Sandro- in forum Video Streaming DownloadingReplies: 0Last Post: 26th Oct 2010, 07:25 -
Audio Compression
By Nitro89 in forum ComputerReplies: 8Last Post: 2nd Oct 2008, 09:00 -
Capture Cards with hardware compression to Xvid/Divx?
By quantass in forum Capturing and VCRReplies: 7Last Post: 31st Aug 2008, 19:50 -
Audio compression with VirtualDUb!
By kehn in forum AudioReplies: 5Last Post: 27th Jul 2007, 00:10
