Is it impossible to have DivX 4 AND DivX 5 installed in windows (XP)? I have a DivX 5 video that I need to convert to DivX 4 and I can't seem to have both codecs installed at the same time. :![]()
Really? It is quite possible, as I have all the DivX codecs on my system. Thet came in the Nimo Codec Pack.
Hello. -
Well, I'm using VirtualDub. When I have DivX4 installed it shows it under my compression codecs in the menu. When I install DivX 5 I go back to the same menu and DivX 4 is replaced completely by DivX 5 in the choices.
I am confused. The question I am asking is: What happens when you install the Nimo Codec Pack?
Hello. -
If I install the latest Nimo 5 final pack, I get only DivX 4 in my VirtualDub compression choices menu. I went through the installation and MANUALLY picked both DivX 4 and DivX 5 to be installed, but only 4 will show up in the menu after isntallation.
New Receiver & DIVX
By denzlite in forum Newbie / General discussionsReplies: 6Last Post: 17th Jun 2009, 06:35 -
Need a program to combine & cut divx, mpg & wmv
By sync in forum EditingReplies: 3Last Post: 14th Nov 2007, 08:02 -
Problem Divx's & Xvids
By ramses505 in forum Video ConversionReplies: 3Last Post: 8th Oct 2007, 10:39 -
Divx Ultra Authoring & The Future
By Tom Saurus in forum Authoring (DVD)Replies: 2Last Post: 19th Aug 2007, 10:02 -
ffdshow -XviD & DivX same?
By tigerb in forum Newbie / General discussionsReplies: 3Last Post: 14th May 2007, 03:16
