Okay I started converting a d2v to svcd and was converting it straight to a removable disk I have (mp3 player) and stopped to save it to my hard disk but when it went to start again it said d2v was unsupprted file type (same warning you get when you dont have the vfapi plugin installed). I tried restarting, re-downloaded tmpge, dvd2avi and vfp plugin but it still doesn't work.
You did not mention if you did any of this:
-- The Newbie GuidesIf you get an error message when opening the video or audio like file unsupported
or you get an empty(black) video preview window
or the video look wierd in the video preview window like green or purple or pink
Be sure that you have installed the DivX Codecs (both DivX 3.11, 4 and 5) and also try with the Nimo Codec Pack. If that does not work try to change the codec reader settings in TMPGEnc under Option->Environmental settings->VFAPI plug-in and right click on the DirectShow Multimedia File Reader and increase the priority to 1 or 2 and try open the video.Hello.
pc crashes when using tmpge 4.0
By ANTS17 in forum Video ConversionReplies: 1Last Post: 11th Oct 2010, 22:55 -
.avs scripts in TMPGE Xpress?
By ecc in forum Video ConversionReplies: 0Last Post: 12th Aug 2008, 07:39 -
TMPGe and BD template the right settings for pal -getting juttering effect
By millzy in forum Authoring (Blu-ray)Replies: 0Last Post: 31st Jul 2008, 10:13
