Hi there,
I have 2 rips of the same movie, one from EPIC, one from a less famous crew, I want to use the video of the 1st one with the sound of the second one.
They are both PAL 25fps, and one is 10 ms longer than the other.
video is divx sbc, sound is vbr 192 kbits
I've tried to demux the mp3 file, then mux the vbr mp3 with the divx3 video in nandub, no luck.
There's no way to hear in the realtime the delay you will input in the "interleaving" window, so I tried with +10 ms delay, the first half is ok, then at the end of the movie, no more synchro.
My last option will be to decompress mp3 sound from both releases, and timestrestch them in Wavelab, but then I'll have to encode in AC3 2 channels if I don't want to compress in MP3 a second time...
Any idea how to fix synchronisation in an avi file IN REALTIME ?
Thanks for any help!
I
