  1. I have 2 movie files which i converted from mpeg1 to mpeg2 with tmpg. I crated a project with DVDit this morning, got the links, buttons and preview to work perfectly. When i go to burn it, it tells me that my CDR wont hold that much data. I have all the settings for my DVD burner but its trying to burn this to CDR and i noticed also that the project size is not what it should be, its not even 1 gig when it when it should be 3.4 . Anyone got an idea what i did wrong ? Thanks
    Aden
    "i wouldnt have compromised as much.. so much of myself for fear of having you hating me.. and i would not have discredited every one of their compliments and i would have run around, screaming proudly at the top of my voice..."
  2. Howdy
    There are known problems with DVDit's disk space estimation... try checking out Sonic's forum at http://forums.sonic.com/
    Make sure you search/read the archives before posting... they can be a bit abrasive to noobs on ocassion.
    Good luck.
    --=Maj
  3. you have to manually change the out put from cd to dvd go into builds, open video settings and click that from cd r to dvd-r and it should show you an updated screen.
