I created two MPEG-2 files with the identical video and audio settings. I then merged those two files using TMPEGEnc's Merge & Cut tool.
When I played the combined file (on my SVCD disc) in my Pioneer 343, the video and audio was choppy. BUT when I played the original two files as separate tracks (on my SVCD disc), they played in their usual flawless way.
QUESTIONS
1/ Have you ever experienced this problem? If so, is Merge & Cut doing something bad to my files?
2/ Apart from the choppyness issue, I noticed that there is a small audio gap in the area of the combined MPEG-2 file when the files meet (even though the merged video looks seemless). Is this normal?
Thanks!
Results 1 to 1 of 1
Are there any software that will SIMPLY cut and merge *.mts without re-enco
By skydutch in forum EditingReplies: 1Last Post: 12th Nov 2011, 04:04 -
How to Cut & Merge mini 10 part mini series?
By skorpinok in forum EditingReplies: 5Last Post: 8th Oct 2011, 09:41 -
Cut and Merge MPEG-2 Files
By flash_49 in forum EditingReplies: 8Last Post: 12th Feb 2010, 10:03 -
How the cut and merge function works on your dvd recorder?
By v1p0n3 in forum DVD & Blu-ray RecordersReplies: 3Last Post: 5th Jan 2010, 05:59 -
Need a program to combine & cut divx, mpg & wmv
By sync in forum EditingReplies: 3Last Post: 14th Nov 2007, 07:02
