Hello friends,
I have 2 troubles as follows: please help,
1/ I want to burn my video into 16:9 movie (my source is 16:9 too) but I don't know how to. When I go into Make dics Options - Compression, I see Media type list is blur (disabled), so I cannot select 16:9 as I want to burn. Someone told me should set Profile being 16:9 but in fact it blurs (disabled)and I cannot get it.
I have to what to do ?
2/ I want to make the motion button state change color when I mouseover on that motion button. Usually if I use button not motion, I can see the button change color state when I mouseover. But when using motion button, it cannot.(although I already render to see preview motion window)
If anyone knows, please help show or teach me more.
Any advice or idea appreciated.
Thank you very much in advance.
Ferrymost,
Just bump(reply to it) your message if noone answers instead of posting a new one.
i think you are using the trial version, or am i wrong?
i used to have the 16:9 problem too.
the only way that i found was to convert with tmpeg.
in tmpeg you can choose the aspect ratio you want.
and then load the converted file into ulead dvd workshop.
dvd workshop will NOT convert the movie again if you
use the standart bitrate and resolution in tmpeg.
this way you can steel author menus to your movies.HELL AINT A BAD PLACE TO BE -
My Ulead DVDWS 1.2 is not trial version. And my Mpeg file encoded by LSX-Mpeg plugin of Adobe Premiere (16:9). I also cannot use ifoedit (I don't know how to use and get it?).
Why this problem just happens to me????
Does anybody have Ulead DVD Workshop SE 1.21?
By OS_Man in forum Authoring (DVD)Replies: 5Last Post: 21st Sep 2010, 02:04 -
Ulead DVD Workshop 2 replacement?
By msimon7 in forum Authoring (DVD)Replies: 26Last Post: 2nd Sep 2010, 09:25 -
Replacement for Ulead dvd workshop 2
By jakewoodblues in forum Authoring (DVD)Replies: 3Last Post: 14th Apr 2010, 22:05 -
Ulead DVD Workshop 2 with Vista?
By SCDVD in forum Newbie / General discussionsReplies: 2Last Post: 17th Feb 2008, 02:48 -
Ulead DVD Workshop 2 error
By SEE_Studios in forum Newbie / General discussionsReplies: 21Last Post: 4th Jan 2008, 02:55
