major -
i've only succesfully (from current tests run) gotten a VERY small vob to convert directly in mpeg2enc (movtoy4m to mpeg2enc) with appending .mov to the end of the file name ( a file 1:29 seconds in size) otherwise i get the error "## Component Manager: attempting to find symbols in a component alias of type (eat /MOV / )"
any ideas?
but it doesnt show that error when i works correctly, it shows a blank line while converting and then encoding complete when its finished.. when i get that error it goes straight through and makes no output file...
Email me some more info about what you're doing and the result you're getting back, and I'll try to help.
major--
i emailed u about the problems i was havin and u never got back to me... i've tried several different things to get certain vob files to work with the trick, even after fixing the improper timestamp and remuxing it still wont read 95% of what i try to feed in... when i appen the .mov suffix and try to open it in qt certain files will open in qt still, those are the files that work, but most of the files that i add the suffix with and then try to open dont open in qt and invariably dont work in movtoy4m-- any ideas?
Trick PSP video
By jntaylor63 in forum Video ConversionReplies: 0Last Post: 4th Aug 2011, 09:42 -
.MOV conversion to .AVI and .MOV HD quality query
By Peewitisland in forum Newbie / General discussionsReplies: 3Last Post: 31st May 2011, 11:22 -
mencoder wont convert the complete file, mov to avi|mov
By bjornieB in forum Video ConversionReplies: 2Last Post: 19th Nov 2009, 07:42 -
Help Nero is not doing the trick
By breeze9 in forum Authoring (DVD)Replies: 6Last Post: 1st Feb 2008, 08:36 -
Is there some trick to putting in a video card?
By videobread in forum ComputerReplies: 12Last Post: 21st Jun 2007, 21:07
