I am archiving 8mm tapes. Want to have the best of both worlds - TV & computer, so decided to do 352x480 MPEG2 interlaced for TV, and a separate deinterlaced version for computer (which is the subject of this post). My target computers can be slow, so MPEG2 is better than MPEG4/DivX. On the other hand, I want to fit at least 30 minutes on a CD, so need to keep the bitrate under 2500-2700. Now what is the best resolution to encode?
Say, I capture 480x480 Huffyuv and smart-deinterlace. Noisy 480x480 MPEG2 may need >2700kbps for best quality, so it is better to resize down before encoding & there are several options:
1) 352x480, same as for TV,
2) the reverse - 480x352, close to the final 4:3 aspect ratio,
3) other (for example, 400x400).
With correct aspect ratio settings in TMPGEnc, all resolutions play fine with PowerDVD, but which gives the best quality? I did a quick comparison, and it looks like 352x480 (so much advocated for TV) is worse than 480x352. But I wonder if people could share their opinions/experience on the subject. Thanks.
Results 1 to 1 of 1
Faster Resolution of Chroma Isssues During MPEG2->XviD Conversion
By onesikgypo in forum Video ConversionReplies: 5Last Post: 27th Apr 2011, 09:56 -
viewing a QVGA/VGA resolution video with NTSC DV resolution (with a TV)
By Lightbreaker in forum EditingReplies: 1Last Post: 6th Jan 2009, 01:57 -
deciding on the correct resolution setting when converting to mpeg2
By Dreadnaught in forum Video ConversionReplies: 4Last Post: 15th Jan 2008, 08:36 -
Do DVD resolution mpeg2 captures require to be encoded ?
By perfection in forum Newbie / General discussionsReplies: 2Last Post: 1st Sep 2007, 17:08 -
I got a projector - it works with my computer but my PC resolution changes
By um4r in forum Newbie / General discussionsReplies: 12Last Post: 26th Jul 2007, 15:16
