Is there a way to fit a 121 min movie on 1 vcd. FFmpeg might work but im not sure. Please help.
Qshartle
"Good Luck 007"
In Memory of Desmond Llewelyn -
im sure there is.. but is the amount of effort required to do something really worth it solely to not get up and change disks? i mean theres a point between laziness and quality that i would think just about anyone wouldnt want to cross... the quality would be totally deplorable if the end file even played at all, the bitrate would have to be around 750, and if you think mpeg-1 1500 is blocky, u dont even wanna know how crappy a bitrate that low would look.
See above....................
If still want to go for it, here it is...........:
http://www.vcdhelp.com/forum/userguides/84759.php
Convert .avi movie files to vcd or dvd without loosing picture quality
By akakiami in forum Video ConversionReplies: 8Last Post: 8th May 2010, 18:01 -
Movie quality for VCD
By dilanalex in forum Newbie / General discussionsReplies: 12Last Post: 21st Apr 2009, 02:42 -
Help with Ripping audio from a VCD (2 discs) to put 1 DVD for a movie.
By shuya_nanahara in forum Newbie / General discussionsReplies: 7Last Post: 24th Jan 2009, 23:40 -
Is there any tutorial that fits a 1 Movie into 1 VCD?
By Rayster in forum Newbie / General discussionsReplies: 3Last Post: 9th Oct 2008, 00:51 -
Help:How to author 3 disc vcd movie into single dvd without reencoding
By devstallion in forum Authoring (DVD)Replies: 6Last Post: 31st Dec 2007, 04:40
